- Nov 27, 2012
- 7,864
I've got 2 different size Tapamatics but I only use em on the mill. I've never seen or heard of a Tapmatic or Procunier used on a lathe. I suppose it would be possible though if one really wanted to.
Just made one and tried it on the part but it's too hair-raising to guess when to stop before the tap might break. I'll go back to manually cutting the last couple threads.
Ive always wanted to make some of these, just haven't had the need yet i guess
It's interesting you say you only use spiral flute taps in your Procunier tapping head. Spiral flute taps are great for blind holes because they force the swarf back up the hole. However spiral point taps are stronger and are better for through holes since they force the swarf out the hole ahead of the tap minimizing the amount that will be captured in the flute.For power tapping I use a Procunier 2E tapping head. What's comforting is that the tap slips as a function of the downward pressure on the quill...a little slipping, just pull harder. I've never broken a tap, though I suppose it could happen. I only use spiral flute taps for this.
I have one of those type too. I don’t power tap. I have 10” handwheel I mount in the back of my spindle and power it by hand.I've got a Vertex Tap Chuck. It's got jaws to grip the shank & holds the square to drive the tap. It's a rigid holder so no slipping, I rarely use it because of that. I prefer to use a keyed chuck for power tapping, I rather the tap slip then break.
View attachment 450323View attachment 450324View attachment 450325
This, all day.Sometimes slippage is your friend when tapping, versus breaking the taps.
I also lock the tailstock and "hammer" in the mt2 with a few taps or it will spin outThis, all day.
I only lightly (tightly lightly) chuck up the tap with most of the shank in the chuck and let it spin to indicate binding or hitting bottom.
Let the tailstock float and walk it’s way in with the tap, then light pressure backwards when it’s backing out.
Ah, good point, neither have I. Disregard everything I ever said, I missed this was lathe related.I've never seen or heard of a Tapmatic or Procunier used on a lathe.
