- May 15, 2018
- 15
I have the inverter running, external forward - stop - reverse switch and pot. I'm trying to wire an E-Stop and it's working reverse of what I imagined (do I have wrong switch?)
I have an ABB CE4P-10R-02 switch from Galaco. Pull it out and it is open, push the button it's closed. Switch contactors I believe are wired normally closed. There are 4 terminals on it.
I have 03-04 set to 14 on the VFD, one leg of the switch is wired to common, the other leg is put into S5 terminal (per diagram in the manual)
When I pull out the button, it activates the rapid stop... push it in, lets it run. I'd like it to work in reverse. Did I get the wrong switch? Is there some wiring trick I missed (I'm by no means an expert with wiring or circuits)
Any help would be appreciated..
