I want to remote this thing out of a box.It has a control panel that disconnects from the body. Has a plug in the back of it for the wires. my question is where do i get that wire that has the plugs on it? will post pictures if needed. thanks
what would the push buttons be for. ? power and? ?Mr. bowkill:
The place you got your drive should have the remote mount device with the plug in it. Wire the plug, mount the device to the wall or stand and plug in the control station. Not all mfgs offer this option and I do not know if TECO does. Wire is just 6 or 8 conductor shielded cable, nothing special.
My two cents worth!
The little blister buttons in those control pads are not very tough as they are not designed to be operated by oily, greasy, swarf covered ape fingers on a constant basis. The main reason they are so handily removed is so the installer can remove them so the average "Joe" does not try to jack with things he should not even touch. I would recommend 22mm pushbuttons. Three pushbuttons and a $5 pot from radio shack and you are in business. Tough, cheap, and really cute!
Now getter done so you can start your own SWARF pile!
CONGRATULATIONS Mr> bowkill: We knew you could do it!
