- Jan 22, 2012
- 45
well I mounted motor and using the TECO JNEV-101-H1. here are the problems (so far); first now when I start in up it jogs backwards. I have to stop it and then run again and now it goes forward. this didn't happen when I simply had it wired and unmounted. second problem is that I have a DPDT switch wired up for the fwd/rvs but I guess I don't quite understand how to program it and this has not worked as of yet.
I plan on putting a SPST switch on the common of the fwd/rvs switch to be able to turn off the pwr to the motor. seeing how yesterday was spent testing the basic setup and tearing apart the G0602 lathe and today was church and trying to get it all going I haven't been able to play with it too much. plan on doing the 10k pot to vary speed remotely if I get the rest figured out. any help and suggestions would be appreciated.
