- Feb 27, 2014
- 2,134
Wow, that is a lot of glass removed in two hours. Do you have to worry about glass dust in the air? I assume it is a wet sanding but when the water evaporates do you have to take special precautions with the waste?
If you look close at the join between the steel disk and the glass you will notice a large chip out. This happened when the vertical pendulum grinder ran away from me a hit the edge. I'm hoping I will be able to remove most of it when I chamfer the edge, if not and it screws up the figure I have a heap of 19mm glass to cut another from.
Still so much to do.
on the positive side, this will give you more time to collect puns.Now the wait for a new one.
Groan. Thumbs up on that one.Ok.
Have you ever used a telescope
If not, you should look into it
