I had the top of the stand welded up and was going from there tomorrow. I started thinking today that I may change something before I go too far with it. Will need to cut a couple new pieces to make the change.
Also I almost forgot the important item. I need to put a 220 outlet on the wall where the mill is going. Also a 110 duplex for lights, power feed, whatever. I have all the necessary stuf to add the outlets so that won't be a problem. I have 110 run along the wall to an outlet at the back of the garage that I can tap into. Also have my compressor Hard wired in 220. I can change that to a plug and use the wire for the Mill.
