- Feb 28, 2019
- 499
I've been putting off adding any sort of coolant system to my desktop CNC for a couple of reasons but it's becoming apparent that I would benefit from using one.
My biggest concerns are the potential mess and the need to now put the machine in some sort of tray to collect coolant.
The machine is a Nomad 3, if you are not familiar with it, it's about the size of a small dorm room fridge. It has a sturdy metal frame with bamboo side panels and a plexiglass door / hood. No real bottom. Any excessive amount of coolant would run out under the y axis table and on to the bench it's sitting on.
My first question is - how much coolant collects and runs off using a small unit like the porta-mist?
Do you think the humid/wet condition inside the CNC cabinet is going to affect the bamboo-ply side panels?
Finally, any other comments / experiences using this small porta-mist system would be appreciated.
I've got a reasonably sized California Air compressor that should have no trouble keeping up with it.
