- Nov 9, 2018
- 377
I'm looking at buying a new lathe. Have a pretty tight budget of around $3500 max. Requirements are
I make prototype parts for engine swaps, so I make things like stub axles, pulleys, flywheels, that sort of thing, so I need a 11" swing minimum.
The PM1228 looks really nice, I really like the smart motor start/reverse, in that it has an electronic brake when you stop it.
If I get the PM1228, I'll mount it on a cast concrete stand, and level it dead-nuts on.
But I don't know, the PM1228 is pretty expensive, and it's about $200 more for the PM1236. But the problem is that's getting way too big for my tiny shop, and it would be next to impossible to move solo, with just my hoist.
Note, I'm willing to scrape / tweak the ways slightly to get dead-nuts precision, but I want a new machine with a freshly ground bed. But I really want a new lathe to make car parts, not looking for another used lathe project.
I'm thinking about either a Precession Matthews PM 1127, PM-1228VF-LB, or I'm thinking about this Bolton CQ9332A
The Bolton, it does look pretty rough, has a "made in India" kind of look to it.
- metric threading!
- need to be able to move it solo, with a engine hoist, I don't have a truck, don't have forklift.
- prefer about a 12x24 size, I have minimal shop space.
- 1.5" spindle bore
- I work exclusively in metric, so I can get by with an imperial with a DRO, but at minimal, need metric threading.
- cam-lock spindle
- small enough to move solo and not take up a lot of space, but rigid enough for real work.
- precise enough to hold tight tolerances (0.01mm) like grinding cam journals (I have a tool post grinder).
- 11"/280mm swing over bed.
Gear-Head Metal Lathe with Stand & Coolant | CQ9332A
Bolton Tools CQ9332A is a 12" x 30" Gear-Head Metal Lathe With Stand & Coolant System. Large Spindle Bore and Travels Make This a Formidable Metal Lathe
boltontool.com
