I am in the middle of learning to machine watch parts on a watchmakers lathe. I also have done a little restoration on it since it was old. I am puzzled by one thing I cant seem to figure out. It has some machine plugs in several holes normally used for wire entry. I have been trying to size these things for a while without success. I need both plugs as well as the need to add a wire gland. I have one of the existing plugs only and it measures 15MM in diameter with a thread pitch of 1.5MM. This is very hard to find so I was thinking of just tapping out the holes to a more available size of M16-1.5.
Can you run an M16-1.5 tap through what is probably an M15-1.5 hole and expand it?
One of the reasons I am doing this is to put in a wire gland. You can see it next to the plug in the photo. Funny thing is that gland is an M16-1.5 and it fits fine. But I had purchased some set screws that were M16-1.5 that didnt fit (too tight). So that was weird. The gland wire squeeze side screws in perfectly but that it would be backwards :-(
Any thoughts on this?
