- Jan 10, 2019
- 1,042
Just asking to see what others do.
After receiving my PM935 mill, I added various things, which required tapping holes drilled into the housings. Even though I was really careful, and used tapping fluid, I still managed to snap off an 8-32 tap in a casting. I realize the larger the tap, the less likely it'll break, but for those particular holes, 8-32 matched the need. Anyway, reading up on it, I'm reminded that I should probably use rolled-thread taps more often, as they're a lot stronger than the cutting type.
What do you guys do to avoid breaking taps when adding accessories to PM products?
