- Jul 15, 2018
- 14
Hello All, I am new here on this forum and I need some information that I cannot find anywhere.
I have a small mini lathe MX180V there was no name on the lathe from new. I believe it would be considered a 7x10 lathe. The manufacturer sent me a manual with the lathe when new, it is not correct (WM180V). The manufacturer insists that it is correct, even with different model number, different threading gears, 220v verses 110v, and more.
This is my problem, see attached gear chart off of the lathe. (Not a good picture) I have 6 gear locations and not the correct gears. I want to turn a 1.0625 x 20 TPI thread on an air rifle end cap.
These are the gear sizes I have,20, 24,30,35,40,50,60,72,80,80. These came with the machine I did not loose any. The chart calls for different gears then I have. I went on line to the little machineshop web site and used their gear calculator and it only shows 4 gears so I am lost.
From what I can determine the lead screw is 16 TPI, there is a 40 tooth gear on the chuck spindle, that is fixed, not changeable.
Looking at the gear chart attached, at the upper right corner you can see the A,B,C,D,E,F gear loctaions.
Does anyone know what gears go in what locations to produce a 20 TPI part.
