Second time threading on my mini lathe today.
Problem I'm running in to, both times, is depth of cut being too shallow.
Thread is 1/2-28. Shooting for class 3 fit with major diameter of .498 (confirmed spot on w/ dial micrometer) and target minor diameter of .457
This should give me a depth of cut of .0205" Lathe dials are standard read, so .001 on the dial is .001 in (removing .002 if turning OD).
Threading with the compound set at 29.5*, this means I should read .0235 on the dial to correct for the cosine.
I cut the threads to that, then went in another .001 on the crossfeed to clean up (which theoretically meant I should have been at .456 minor diameter).
The problem I'm running into is I'm still not deep enough to either form a V or screw on a test nut. I even went another .003 or .004 and I'm still coming up shy, so it's like I'm not even close. I touched off, did a scratch pass, ect so the initial depth setting was correct.
I put a dial indicator on the compound, and it's off .001 which i took into consideration so, on paper, my cut was correct if a touch over.
I bought a die as a way to hedge my bets, and ended up using that to finish the thread, but would like to remove that necessity in the future. I realize the huge limitations of my equipment and I may just be running to an inherent issue with the machine, but thought I'd ask to see if someone can catch something I'm missing. Checking with wires would probably be my best bet but I wouldn't use them nearly enough to justify the investment.
