- May 27, 2016
- 3,471
Well - not all threads - just one thread in particular!
I happen to tangle with the fat T-nut stud that holds down the toolpost on my South Bend 9". The thread is a bit mangled right near the top. I guess a previous owner was careless with the lever nut. The hex nut under would not come off without some "persuasion". Just one of those little things we encounter all the time.
It measures 1/2", near exactly. I reach to the (few) dies I have. Hmm.. the 1/2" one is 20TPI - so that's UNF, and we are coarse thread - no good.
Rummage some more. There is a 1/2" 13TPI. That's UNC, and it won't fit! Just what is this?
Get out the thread gauges. It is exactly 12 TPI. Ah..Haa - so it must be a Whitworth!
Eh? Check threads carefully. 55° is definitely not it. Not Whitworth then. Check harder. 60° is definitely the thread cut!
I give up! This stud is a oddball one-off. 1/2" , 12 Turns per Inch, and has 60° threads.
I settle for a fine horology kite-section file. Maybe I will replace the whole shebang with M12.
Meantime, the farm neighbours behind have had the call to get shot full of vaccine. I anticipate my turn cannot be far behind. Yay! I so look forward to leaving behind a year that was so forgettable that I can't remember much of it, other than it slipped by while I hid out in the country like a hermit for 10 months. Just hanging in there hoping to make it to vaccine relative safety before the damn pestilence catches up to me. I know I don't much fancy my chances if it does before I get safe.
Why should I get to feeling so sorry for a silly chewed up thread? It's no big deal - right? Maybe I'm getting a little emotion affected symptoms. That's OK. I can read H.M. postings till the cows come home, fit a door frame, and fix up the mangled thread, and feel OK again!
