- Feb 7, 2013
- 2,486
Today I decided to clean up an old capstan that came from the scrap yard several years ago. On inspection,
I found out why it was discarded. One of the teeth on the big gear was missing! I saw that as an opportunity
to fire up the Everlast TIG welder and at least try to attempt a repair. I thought of gas welding on a tooth with
some brass but with a new TIG sitting there, I didn't have to cogitate too long to decide what to use.
The biggest difficulty was seeing what I was doing but I could see well enough to see that the base metal was
melting. I fed in some pieces of broken piston ring for filler rod in the process. I did some rough profile work with
my 4.5 inch angle grinder using a thin cut off tool. The repair looked better than some of the other teeth on the
gear so I think it will work OK.
Yes, it looks a little rough but probably fine for what I am going to use it for.
It turns freely past the new tooth! It would be a handy tool to pound in a sand point well. It can be powered with a small gas engine and also has provision for
using it on a PTO. Now I have to wait patiently until the ground thaws around here...
