Motivation is the key, fear not, I can't remember what I ate last night. Wish I had a home shop,
I do not, I have a business shop and days like today 33 degrees sleet mix rain yeekey, I aint a comming
out. Ole bones don't like the damp, don't ya know; & the shop heat is 70 (I hope) So what you got for
a shaper, that's the most used machine we use here cause stock is cleaned up first, then milled.
I know I'm ramblin again said this million times; just why use expensive end mills on rusted
stock when a $2 HSS ground bit lasts forever, and grind it over and over? They will produce a finsish
that you can shave with. secret is grinding the tool.. Few yrs back I scored a 2x2 by about 5 ft in
the woods, think it was a wagon axle, been there 100 yrs, chop sawed it, into 3x2's stuck it in the
shaper, squared it, made V blocks - blocks in general, and jack blocks. The left overs I shaped
wedges, wedges rule for clamping on the mill. All free junk stuff turned into tooling.........
ther ya go get in there and make chip samuel
