[4]
Tiny Basement Shop Progress
[3]
[10] Like what you see?
Nelson
Founder & Former Member
H-M Platinum Supporter ($50)
Sep 22, 2010
6,029
Likes
499
#1
I applied sheetrock, then 3/4 inch plywood to the walls to prevent damage.
I installed built-in shelves. I covered the gas main and regulator with a plywood cover. Unfortunately, the gas meter is right on the tailstock of my SB H-10 lathe, which is in pieces here. I need to get Con Ed to move that meter out of the way.
As with the other walls, I first applied green board (old resistant), then 3/4 inch plywood to prevent the Van Norman #12 (shown partially assembled) from smashing up the sheetrock (which it did before the plywood was installed.) Temporary shelves hold some tools.
Sheetrock is covered with thick 3/4 inch plywood so the Burke #4 does not smash it up. A panel of plywood was split then brought down to the basement and reinstalled.
Thi is the view of the front basement wall from the hallway outside my shop. I made a wooden sliding barn-type door to close up the shop area.
Tony Pisano
Active Member
Nov 2, 2017
60
Likes
57
#2
Looking good. You can do a lot with a small space if you are organized.
D
Deleted member 17524
Guest - Please Register!
#3
Nice shop Nelson. I have one small concern though and that is the location of that Gas Meter. Here they check them every 2 years and replace them every 10 years. I have had mine spring a leak. Not bad enough to evacuate but still a leak.
"Billy G"
Nelson
Sep 22, 2010
6,029
Likes
499
#4
There is a Baldon #520 Carbide grinder, an old one, circa 1960, that is located in the alcove where the power panel is.
Nelson
Sep 22, 2010
6,029
Likes
499
#5
"Billy G"
Con Ed never replaced the meter. That is the original one, and the placement sucks. I'd be happy if it sprung a leak. They would be forced to come right over as an emergency and replace it. I am going to write the Public Service Commission. When that happens, Con Ed responds, and ask that the meter be moved.
Word is they are FINALLY going to put in remote reading, like the water meter. It is about time.
D
#6
Remote reading will not help per say as the meter will be the same, just a sending unit added. I check mine from time to time using soapy water to find any bubbles. If I see them they will surely get a call. I'm not completely sure but I believe that changing them is mandated by the Federal Government. Call the town hall building dept. They will know for sure.
"Billy G"
DougD
H-M Supporter - Gold Member
Mar 29, 2015
55
Likes
14
#7
Nice space utilization. What is the size of the shop?
Apparently I missed something, where was your shop set up before?
doug
Nelson
Sep 22, 2010
6,029
Likes
499
#8
"Billy G"
Bill,
I think you are right. They didn't follow the law- they don't care. You have to write the PSC before they will do anything.
Nelson
Sep 22, 2010
6,029
Likes
499
#9
doug
It is about 10 feet wide by 8 feet deep- very tiny.
It was set up in the same location, but no walls, just plain studs. Nothing to hang anything on .
There were "boxes" for built-in shelves, but they had no backs, so that things fell down behind the shelves, where they were irretrievable.
I put green board everywhere, then thick 3/4 plywood screwed to the studs. You can screw shelves and anything else you want to the plywood.
When you remove the plywood, there are walls, so if someone wants to put it to another purpose when I die, they can.
I removed the old box shelves, and made new shelves with 1x8 boards and plywood backs (3/4"). You can nail things to the backs or do whatever you want. I made some stops for shelves. I intend to put the tooling for the Heavy 10 and the drill presses behind them.
I bought USA made polyurethane floor tiles- the expensive ones- that you can roll a heavy machine over. Need to put those down.
DougD
Mar 29, 2015
55
Likes
14
#10
That should really be an improvement for you, and again good utilization of the space.
doug
Old Mud
Aug 8, 2016
97
Likes
125
#11
Tell them if they don't move it your going to hook it up to your lathe for power !! That should bring them down at least for a look. ;)
Nelson
Sep 22, 2010
6,029
Likes
499
#12
Con Ed is refusing to move it.
They want me to hire a plumber and do it. That will cost a lot.
I will have to just work around it, and hopefully no leaks happen if I lean into it.
Then Con Ed would be forced to do something. :laughing:
Nelson
Sep 22, 2010
6,029
Likes
499
#13
I desperately want to get my clock shop and machine shop areas going.
In July, I will be 60. It's about time I did, while I still can work with this stuff.
Ray C
Platinum
Staff member
Nov 16, 2012
5,215
Likes
1,445
#14
Are you thinking about making clocks or repairing them? If you're thinking of making them, what kind do you have in mind? Have you picked-out any plans yet?
If you have a goal in mind then, you can start setting-up the shop specifically to achieve that goal.
Ray
Kiwi Canuck
Oct 27, 2016
219
Likes
191
#15
You should be able to move that meter yourself and have a gas fitter "inspect" it for you.
There is a special pipe dope (or teflon tape) you can buy that is rated for use with Natural Gas.
I do all my own black pipe work for air and gas and if the job is permitted or needs an inspection, I have a gas fitter friend drop by to sign it off.
It's very easy to do and quite fun.
David.
Old Mud
Aug 8, 2016
97
Likes
125
#16
Not to worry Nel's, in June i'll be 79 and other than a messed up back and a rebuilt heart i still work in my shop. yahoo.gif
Just a thought, even if Con ed dosn't want to move it you could consider it a safety hazard. There must be some Government agency that could help you ? Maybe Osha ?
Nelson
Sep 22, 2010
6,029
Likes
499
#17
When I have the money (this won't be cheap), and am just going to have a licensed plumber do it.
Apparently, there is an inspection, and engineer required in the City of NY (sucks, doesn't it?), so I have to go that route.
I put in the piping for our gas dryer. The fools that owned the house before me were using a rubber hose that was connected with a clamp, and no valve. But this is more extensive, and requires filings by a licensed plumber.
Old Mud
Aug 8, 2016
97
Likes
125
#18
Wow that's scary, a licensed plumber AND an Engineer ?? Good grief !!!
Eddyde
Bronze
Oct 13, 2014
1,423
Likes
1,209
#19
Yup, NYC bureaucracy is a living nightmare... I'm a contractor and moved several gas meters in my time, The most important thing is passing the pressure test, I'd advise the plumber run this test before he does any work, that way you'll know if you have a leak in the existing system if so, and you cannot find it, you can back out of the project (of course only if its an extremely slow leak). Once you do the work the system must have absolutely no leaks or they won't turn your gas back on. I have seen cases of buildings going without gas for months till they found the leak, usually involving ripping open walls and replacing the most of if not the entire system...
Ferrous Turner
Active Member
Apr 4, 2018
53
Likes
140
#20
Cozy little shop you have there. I always wanted a basement, but they don't build many out here in the west. I converted my garage, as many have, but I'm still running out of space. Material storage is always an issue for me, and for you too I would imagine.
[6]
[5] [7]
