- Mar 27, 2022
- 425
Hey all I am trying to level out my sheldon lathe. I dont have a precision level, I figured I would use my construction level to get things close after placing the lathe. I am "close now" but I have ran into a problem, I cant seem to get the twist out. I mounted a level on two flat surfaces of the carriage and moved it from end to end. I am using the adjusting nuts on the cabinet(steel desk construction not cast) and have gotten to the point that I need to raise the rear leg at the tailstock but the front leg at the tailstock is currently floating. I dont have a test bar or even a long piece of metal to play with to see but I did turn a patch on a bar about 1.5 inches long and got 4 thou of taper. It tapers smaller towards the tailstock end. This was done unsupported with a 1-2 thou cut at the slowest feed. This is repeatable on cuts.
This leads me to believe either the front tailstock adjuster needs to lower or the rear needs to raise but it is currently floating on the front. I suppose I could bolt down the front leg to the floor? Right now I left it floating so maybe it wants to relax itself down while resting.
Most of what I do isnt "high precision" its always as precise as it needs to be. But 4 thou seems like a lot. I have a ram from a hydraulic cylinder that is in good shape but scrap. I am thinking of measuring it to see how consistant the size is and if reliable chucking it up as a test bar equalize runout along the bar and use a indicator on the carriage to sweep it and see if the issue is just bed wear near the front or real twist. I have basically confirmed it is bed twist as I cant get it level but figure I would get more info.
So after all that mess of words I am hoping for some advice on how to level it more and if my thought on the test cut matches my thoughts on which leg needs to move which way.
