- Feb 1, 2015
- 9,646
There is a big difference between a large lathe and a hobby class lathe regarding available hp and rigidity and the rules are different. What works well regarding feeds and speeds on a large lathe will simply stall out on the smaller lathe. As you become more familiar with your lathe, you will get to know what works for you. My advice is to be conservative rather than aggressive in your approach working your way up.
When stalling the lathe while using carbide, you can sometimes save the tool be stopping the machine and reversing the chuck by hand to clear the jam. It doesn't always work though. High speed steel is more forgiving and better suited to small lathes. It is also much cheaper since tools can easily be reground and put back in service. For a small lathe 1/4" tool bits work well. Any larger sizes offer no real useful improvement in rigidity as they aren't the week link. They are also easier to grind and considerably less expensive.
