I made sure that the indicator point is on the lathe centerline. Put a rod in 4-jaw, adjusted true. Used a height gage to determine lathe C.L. height from cross slide top, then used that number to adjust the height of the indicator plunger. (CL Height + 1/2 thickness of indicator plunger)
