[4]
[Newbie] Tooling that came with lathe
[3]
[10] Like what you see?
DiscoDan
H-M Supporter - Gold Member
Jul 16, 2018
287
I received the following tooling with my 12x36 craftsman atlas. There were no holders for the inserts and the labels on the boxes are not very readable. What are the round and square inserts for? I have the lantern tool holder. Will the big cutter just fit in the tool holder? Thanks
benmychree
John York
Jun 7, 2013
2,865
The pictures are not too clear, but to my eye, none of what is shown is appropriate to your lathe, so far as size is concerned, the triangular inserts? look like they may not be cutting tools, but instead, look like anvils that go under inserts in the holder. The round inserts are more or less unusable on a lathe such as yours; I'd be able to hear the chatter at my house!. The square inserts are just plain too big for a small lathe; what are they for? removing a lot of metal from big work, they would sit at a small angle to the work and do straight turning or facing. I think the round inserts are for finishing straight turning, I have a bunch of them, but have never used them.
jdedmon91
Active Member
Dec 29, 2017
399
Where is the tool holders? I agree with benmychree that they look big for you lathe. However you can modify the tools holders to fit your lathe. However if you set the tools to center hight and take cuts appropriate for your lathe the tools will work as well as the smaller inserts. I routinely use modified tool holders on my G750G Grizzly with a BXA holder. I’m attaching one of my videos to show how I do it.
DiscoDan
Jul 16, 2018
287
jdedmon91, there were no tool holders with the inserts. The only tool holder I got was the lantern style. I am really curious though what type of operation would use the round or square inserts. I may end up selling all of the inserts just to recoup some my investment since I will likely never use any of them.
jdedmon91
Active Member
Dec 29, 2017
399
Round or square inserts can be used for facing and turning with the proper tool holder. The draw back is you cannot machine up to a shoulder.
There are no holders that will work on a lantern style post without huge modifications. I thought you had a QCTP and the holders my bad.
However if you upgrade to a QCTP you could adapt tool holders to fit. Take the insert style do a search for the holder to fit the inserts. The drawback is the holders may be more expensive than just chucking the inserts and buying proper tooling.
In my case I got the tools and inserts basically for free so it was worth my effort
benmychree
John York
Jun 7, 2013
2,865
My experience with trying to sell inserts (I have many hundreds) is that they are nearly worthless, especially if they are negative rake styles, as these look (possibly) to be. If one wanted to use carbide on the Craftsman lathe, it would likely be best to stick with a common positive rake style such as a TPU or G, 320 series, this is a triangular positive rake style that cuts freely and can turn to a square corner, and likewise face to a square corner.
Better yet, learn to grind HSS tools, they are better suited to the capabilities of the lathe and much cheaper to use for hobby work.
TPU is a "utility" finish, TPG is a ground finish, 300 is a 3/8" Inscribed circle size of triangular insert, the 3(2)0 denotes the thickness of the insert, in 1/16ths; a perhaps 1 or 2 replacing the last zero denotes the point radius in 64ths, I think.
jdedmon91
Active Member
Dec 29, 2017
399
Well I use negative rake tooling every day on my Grizzly G0750g. My go to tooling is a MCLR 16-3 witch takes CNMG 432 inserts. This is one of many I have dovetails machined in to fit my lathe. Before a had a 9x32 Lathemaster that used AXA post and I had the same tools modified with it. I sold the tooling I modified with it.
I’ve even sent one of these tools to other individuals who tried them out with success. IHMO the positive or negative rake isn’t as important as HP available at the spindle. That controls the depth of cut. Now I will admit the chip breaker in the inserts makes a difference and if I was buying inserts to use I’d recommend finishing inserts for the narrower chip breaker to correspond with the depth of cut one can take with a hobby lathe
T Bredehoft
Dec 27, 2014
2,833
The large, rectangular tool, while it may fit in your lantern tool holder is not designed for that purpose. It needs a different tool block. The tools that use the lantern, have openings in them to accept square high speed steel tools which do the cutting.
benmychree
John York
Jun 7, 2013
2,865
My triangular inserts that I use in my 19" lathe are held in a Aloris double ended holder, which allows both turning and facing; the holder has adjustable chip breakers that can break chips in nearly All situations, from heavy roughing to fine finishing. I have two holders, one is positive rake for most all uses, and a negative rake holder for interrupted cuts; the negative rake inserts hold up much better than positive inserts under difficult conditions, but use much more power and do not finish as nicely, also, they have 6 cutting edges rather than 3, as with the positive inserts.
"Horsepower at the spindle" that is why I would not recommend negative rake on low power machines; they just do not have much horsepower available, not to mention the amount of pot metal used in their construction, they are simply not made for high or even moderate cutting forces that predominate with carbide tooling.
jdedmon91
Active Member
Dec 29, 2017
399
The advances in carbide and tooling has been mainly used in high power and higher SFM associated with larger CNC lathes. With that being said I had a supply of insert either from testing, gifts or replaced by the latest and greatest thing.
Also the popular CCMT metric size inserts cost per corner is expensive. The Aloris tool described is a excellent tool and works well. However after asking folks who have forgotten more about carbide than I know their opponent is concurrent with what I post the machine is the limited factor in older machine not the carbide.
Since I have a supply and adapted tooling I’m using my “inserts that don’t work “ and smiling at the cash I’ve saved
NortonDommi
Active Member
Nov 15, 2016
431
The round inserts are called railroad inserts and are used for profiling where you don't need square corners. Very handy and you could make a tool holder quite easily but until you upgrade to a better toolpost I would just chuck in the back of the toolbox. The square ones are design for a clamp style holder and can be used for turning/facing/putting in a chamfer, again handy but need the correct holder. I have a big bag of used ones and braze up tools for use on my shaper. Being Carbide you need a Diamond wheel to grind. You could make a small scraper.
Inserts are good but need a lot of different holders and if you start mixing retaining styles can cause clutter very fast.
I'd suggest upgrade your toolpost and maybe buy a set of cheap brazed tip tools to complement standard Armstrong HSS tool holders or a tangential tool holder like the Diamond from Eccentric Engineering.
[6]
[5] [7]
