- Aug 29, 2019
- 579
Today is the first time the motor has been spun by the controls on the lathe. Lots of work left to do before it is ready to make chips, but it's came a long way from where it was when I unloaded it off of my trailer 3 years ago. I don't call a clean and repaint a rebuild but I did strip down to bare metal and prime and paint it. Next step is to get the belts on it and get the hydraulic speed control working. Not an easy task putting 2 gear belts on by myself, but I will get it done. Once i have the chuck rotating next will be the precision work of rebuilding the cross slide and re bushing the apron crank bearing. It all sounds easy but if it was, I would already be finished. When finished it will have new cross slide screw and nut and the ways of the saddle will be built back up with Moglice. If the winter doesn't keep me in the house hopefully it will be all finished by spring of 2024. I've got other machines that I am in the process of getting back in shape so as the pieces come together, I will be back Tooting my Horn. LOL
