- Dec 27, 2012
- 348
38258 - TTS SuperFly Cutter Kit
The TTS SuperFly Cutter(TM) includes: fly cutter body, tool bar, two general purpose carbide inserts, two polished carbide inserts for aluminum machining, insert Screw, wrench and anti-seize
www.tormach.com
this fly cutter is supposed to be quite good. For $145, it should be. I would assume the short shank on this would not preclude it from being used in an Er40 collet chuck or milling chuck on a manual mill? what is the shank diameter of TTS? Thanks
