Tos Trens European Made Lathe ???
FOMOGO
Sep 2, 2013
5,142
Wondering if anyone knows anything about these machines. Thanks, Mike
TOS TRENS European Made lathe
Model SN 32 made in 2001
14 x 40 Lathe
Swing over Bed 13"
Swing in Gap 20-1/2"
Bed Length 30"/40"
Swing over Crosslide 6-1/2"
Crosslide Travel 10"
Spindle Bore 2"
Spindle Mount D1.6
Speeds(16) 14-2500
Motor 5 hp
Weight 3,200lbs
I run a Trens 64? model where I work, 24 x 100, 37 in the gap.
Nice machine, well made and fairly quiet and has inch and metric threading and 11 to 1000 RPM in about a dozen steps.
Also powered rapids with the push of a button, cranking the rather large and heavy carriage up and down the bed gets old fast.
I would recommend this manufacturer.
tos is considered a fairly decent lathe manufacturer around this part of the world
if it is in good shape at a decent price you cant go wrong with it
Wreck, Thanks for the info. I would like that one you run, but I think it would be out of my price range. Janvanruth, they are asking $4900, comes with one bison 3 jaw chuck, steady and center rest, and minor tooling, and dro. Been trying to talk myself out of it, but I think I'm going to see if it is still available. Thanks, Mike
If it's in good shape $4900 is a good number unless you have to work around the 3Phase power problem for a home shop. Does it come with a tool post? I don't know what size QCTP is on the big lathe since there are no markings on it just the Aloris logo, I put my Dorian BXA next to it for scale, the 14" lathe will need something in between these. We have a 2 1/2" Dia X 15" long boring bar and holder that weighs nearly 50 LB's, it's just about the opposite of "quick change" (-:
The spindle has a brake that is activated when the handle is in neutral, it doesn't work very well on this one but is probably an adjustment problem that I haven't looked into yet.
