- Dec 5, 2017
- 464
After the initial successes, life got in the way and it also developed a starting problem, so it sat in the back of the barn for a few months. Once started, it ran fine, but it was a beast to start, usually requiring the battery charger set on boost.
Had a couple of slow days and got curious about the starting issue, so I dug into it. My first suspicion was bad glow plugs, so I pulled them out and bench tested them. On the bench they worked just fine. I buffed up all the connections and put them back in the engine. The connections, especially the jumper between the two plugs, were pretty corroded and after putting them in I wondered if maybe that was the problem. Sure enough, it started MUCH better and without help from the booster. Also discovered that it likes a LOT of throttle to start. The other diesels I have just want the throttle cracked.
With the starting problem fixed, I decided to do a little finish work. The original instrument panel was trashed and the mechanical drive tach from the Shibaura wouldn't fit in the original space, so I polished up a piece of stainless I had laying around and blanked it off. The fancy decal adds at least 5 horsepower!
I added the new instrument panel to mount the tach and while I was at it I added an ammeter and an indicator light for the glow plugs. I had just been listening for the timer relay to drop out, but with my hearing that was not a very dependable method.
So that's where she sits today. As I mentioned, the steering needs a little more love. Also, it has a 2000 RPM front PTO that's begging me to find something to run with it, plus two hydraulic outlets. The JD hydraulic pump is part of the transmission. I removed the pump that was on the Shibaura engine and blocked off the mount to eliminate the need for a tank and plumbing to keep the pump from burning up. It's sitting on my "maybe someday spare parts" shelf.
