I had an emergency job fall into my lap last night at 6 pm. My buddy was going to true up the head on a 1.4 liter engine for a relative. His mill was already set up for an urgent job so he brought the kid over to me.
It took an hour and a half with set up and a couple of cautious passes before I got into the meat of the matter.
It took 0.012" to clean up except one small mark with no depth. I used a fly cutter that covered the main surface in one pass but I had to move the Y to cut the tabs that stick out on both sides. The cut overlap is so good you cannot feel it with a fingernail or pick. I know it's not idea but the head is dead flat.
I am sure to get an earfull on how it won't work and is ruined forever.
The finish is extremely smooth. No idea of the RA but it's near a ground finish. Is there such a thing as too smooth? Should I feed a bit faster to create some "tooth" to the finish? I used a dcct insert for aluminum. I've never seen such a nice finish off my big fly cutter. 660 rpm and around 2 ipm feed.
