- Nov 24, 2013
- 257
The attached pictures show my set up to cut 2 corners of the 1”x1”x1” long aluminum bar at 45 degrees by 0.250” (first I will do one corner and then flip it to do the opposite corner). I made a template shown in the picture to position the piece in the vise at 45. I will be using a 4 Flute 1/4" End Mill to do the job in several steps. The pictures of the lathe are taking looking at the back of the machine.
The attachment to the lathe is the compound slide and I covert it to a milling attachment. The vise holding the piece is homemade while I’m waiting to choose a proper vise.
The purpose of the 45 degrees cut is an attempt to make a mini QCTP I follow on a thread
Is the procedure acceptable?
