Because it's a slip fit into the one end shown and secured with set screws.
I have the rod cut and the lever on the transmission shaft adjusted. It was a long process trying to get the trans into all the gears within the travel of the shifter arm from the aftermarket column. I got it together and tightened the set screws and the first time I moved the shifter arm on the column the rod pulled out. I tried to tighten it just a little more and the set screws stripped out. There was only one full thread on the set screws before they hit the rod to tighten it. I knew they would strip if I put to much torque on them but I had to try.
I was trying to get everything worked out before welding it but no dice. So I came up with a round collar (top right in picture) that fits over the adapter and has a 1/4" allen set screw in it that I positioned over the hole I drilled to do the rosette weld. So far so good. I hesitate to weld it before I get the car ready to start it up again and make sure I have all the gears available and that my neutral safety switch works correctly. I had to make a plate to move the switch over some since I put the adjustable lever on the gear shift shaft. I need to pull the plate and round the edges off and bead blast and paint it now.
I guess you got to be under that and fighting with it to understand. I put adjustable camber arms on my 350Z and they were a similar setup but much beefier. It used jam nuts on the same kind of heim nut. Anyway, people don’t understand the ups and downs of serious customization. Give her hell!
