hoooo boy! Hate to say this but.....
That looks like a 7x bedway, 7x apron and saddle, 7x cross slide, 7x compound slide with a deeper compound rest and a 7x tailstock with riser block.
I seriously hope, for your sake, that is not a 7x bed but a better, heavier casting.
Headstock is of a different design, not sure if integral motor and spindle though?.
You think a 7x is flimsy and flexes? this looks worse.
The part of the picture that shows the lathe has been shoddily resized (unless Vevor have started making elliptical handwheels!
) so it may look a bit narrower than the product is.
It looks a bit like a headstock from the Weiss WBL180 (the base machine that the Warco WM180 is based on/re-badged from) plonked on a Seig/Real Bull bed, a very basic apron attached to some manufacturers saddle (Real Bull or a Weiss WBL1835 I reckon, not the Seig H-shaped model) with a pretty insubstantial tailstock to boot.
Honestly
@CaseyBrownKnives if you
can cancel the order, I'd recommend that you do so.
If you
are set on a new lathe (and I get that buying a used quality lathe is often a frustrating and disenheartening experience), are the mini-lathes from Little Machine Shop or Grizzly so
very far out of your budget?
Mini lathes from those two suppliers will probably come with fewer problems, you'll have decent support and the problems they come with (and pretty much
all Chinese mini-lathes come with fit and finish problems that require
some work to make them usable) are unlikely to be
fundamental, RTM-causing problems.
Vevor is well known as sellers of lathes that are apparently cobbled together with parts that appear to be reject-bin parts from the main manufacturers (Seig/Real Bull/ Weiss), and the sellers of Vevor mini lathes very rarely offer decent support, and Vevor are almost
never any help at all.
Whether it's being patient with some saving, or being patient when looking on the used market, getting the best lathe you can for your money is definitely a patience game.
I do speak from experience here; I think I got
reasonably lucky with my Amadeal AMA714B (a slightly modified Weiss WBL1835 rebadge) but I've had to put some hard yards (enjoyable, though) into fettling it into usability and I'm not finished yet.
I suspect if I'd bought a Vevor mini lathe, I'd have given up by now and be looking for a new hobby.
