- Apr 8, 2021
- 73
Most beginners aspire to great accuracy with common lathes, if you need more accuracy just modify your techniques, turning on centers for making grinding spindles for example, turning on centers will give a straight product if you take an overall cut, mike it, and adjust the tailstock to correct the taper if any.
Turn your compound slide to 5 degrees 42 minutes this will give you a tenth indeed for every .001 on the dial, carbide radiuses inserts can give great finishes .
Better yet get a small tool post grinder, grinding will increase accuracy close to ten fold. I rebuilt spindles this way at work spray welding and turning and grinding journals. Tailstock offset is an old technique
somewhat ignored today as is grinding in the lathe. I rebuilt Sargent Welch vacuum pumps regrinding the rotors and stator body on a 14" Engine lathe saving the company $2000.00 replacement costs.
