Dear All,
I am having a frustrating problem. I can't turn between centers without getting a taper.
Here is the set-up:
1) Sherline lathe 4400, purchased in February 2015. This lathe was sent back to Sherline for adjustment of the tailstock (which was off a bit). Sherline reports the tailstock is now very well aligned.
2) I want to make a shaft that is 2" long, with each end being .19" in diameter for .19". The intervening diameter (between the two .19 diameter ends) should be approx. .09" in dia. This is thin enough and long enough that I need to turn this using a center in the tailstock.
3) I am mounting a 3/8" dia brass rod in a three jaw juck. The rod is center drilled on the outboard end (drilled with the stock snugged up short in the chuck) and extends from the chuck about 2.25 inches. A live center is mounted in the tailstock, and this is snugged up against the outboard end of the stock and locked down.
4) I then attempt to reduce the stock to .19 diameter over most of this length. I am using HSS, turning at 2500 rpm. I am getting no chatter. My final pass is .005 DOC.
The problem:
When I turn a bit of 3/8" brass rod stock between centers to bring to down to .19, I am getting a taper of .06 over the 2" that I am turning. So, if the end of my shaft in near the chuck is .190, the other end will be .196. The tolerance on the part, for the ends, is .002. So, I'm sort of screwed. Yes, I could swap the thing around and machine both ends close the chuck, but then there is no guarantee that they will be concentric, which will be important for later machining operations. Plus, this seems wrong.
In the below photo I am showing the diameters at points 1.5" apart to correspond to the next test (see below)
To see if the headstock or chuck are misaligned, I took a piece of .75" dia aluminum, approximately 2" long, chucked it in the lathe, turned it down down to around .5". Again, my final pass was .005 DOC.
Over 1.5" I am getting 0.000" of taper.
My request:
Please look over the photos of my set up and tell me what I am doing wrong.
Thanks,
Tom
Here is the set-up:
The problem:
My request:
Thanks,
Tom
