Type of Drill
ddickey
Apr 21, 2016
3,572
What would be the particular use for a drill like this? It an NTM 3069c55-001.
They can be used for various purposes. For some, the reduced diameter provides for reduced drilling pressure and better final hole finish. They can also be ground with an flat or angled secondary cutting edge for simultaneously creating a through hole and counterbore or countersink.
Often used in production. You can drill a hole for a socket head cap screw where the screw goes thru plus the cap screw head can be countersunk at the same time.
Or you can drill and chamfer parts at one time. Time is money in production work. I have used hundreds of drills like that. There is a company in Downey Ca that is named Step Driils unlimited that grinds them to whatever size you need.
That one looks like the the small is a tap drill and the large is clearance
Sent from my SM-G530T using Tapatalk
I have couple of them, they are counterbore, often used for allen bolts.
There are four steps. First is .375 & the last is .625. .521 & .578
