- Aug 5, 2018
- 261
Hi,
I have both a mini-lathe and mini-mill and I am following the instructions in an article about making tapered saddle gibs for the lathe carriage that are adjusted from the ends rather than underneath.
The first step is to make a tapered jig out of a piece of aluminum bar stock by placing a round pin under one end and milling until I have milled a taper.
Now, this is my issue:
I used a piece of 1" x 2" x 6" extruded aluminum bar stock to make the jig which I clamped down to the mill bed making sure it was flat and not lifted due to the way it was clamped.
After several passes starting from the high end to the low, I noticed that the machined edge on the low side was not perpendicular to the front edge of the piece. It was slightly angled to the left about 3-4 degrees.
After completing the taper operation, I measured the front and rear of the taper, on the high end and there was a difference of 12 thousands. This explains the machining edge.
Now, What does this mean?
Is my mill head not aligned properly to the bed or...?
I do not have a clue but it seems to me that I should not continue until I determine what is going on here.
Regards,
Red
Regards,
Red
