- Dec 28, 2018
- 21
This is my first post and I'm a real newbie on this stuff. Please be kind.
This past summer I bought a Grizzly lathe and drill/mill. I only use the equipment occasionally. They are in an unheated shop in Michigan so it can get pretty cold. I was using the mill yesterday and the motor to lift the head really struggled to move the head up. It was even a bit hard to crank it up. Once it started moving the motor would work OK. I had no such problems when the shop was warmer. I called Grizzly tech support and they suggested I clean the grease off the jack screw and replace it with a light oil. He also suggested to go back to normal lube in the Spring.
I'll give that a try but wanted to ask a broader question. What lube do you use for your equipment in sub freezing temps, including the ways? I did a quick search on the forum and couldn't find the answer.
Oh, oh...another lube thread, but with a twist.
