Unknown Cross vise
Old Iron
Sep 29, 2010
1,558
I have had this for over 20 years and only used it a few times, I ran across it the other day and figured I needed to clean it up.
The only markings on it is T50 nothing else. I know it couldn't have come from China but mite be from Japan.
It is well made with jibs and numbered dials. So anybody got a hint about who build this thing.
Paul
darkzero
Global Moderator
Staff member
H-M Lifetime Diamond Member
Nov 27, 2012
6,168
Could be HF but not necessarily. Casting differs slightly but then again castings & hardware can change over the years too. Is it T50 or 150? I would figure 150 which probably means it's a 6" size so it's most likely an import.
Old Iron
Sep 29, 2010
1,558
I figured it was a import just not from China, It is tight with know slop a little back lash but that can be fixed.
I'm going to fixed it up and use it on the drill press.
Paul
OldMachinist
Bronze
Rest In Peace
Mar 1, 2012
1,140
Probaly not made in China, 20 years ago Harbor Freight tools would have been made in Taiwan or Japan.
Ulma Doctor
Infinitely Curious
H-M Platinum Supporter
Feb 2, 2013
1,132
i got mine at a flea market,cheap.
after a lot of cleaning and lapping the dovetails smooth,it functions surprisingly acceptably.
i have used it about .003'' accuracy ,repeatably, unless you lean on the screw too hard, then all bets are off.
have fun with her!
mike:))
KBeitz
Apr 17, 2018
532
They are great for making ring cutters for a wood lathe...
Joe in Oz
Sep 24, 2010
136
I bought one of those a few years back. It was really poorly finished. So I took to it with scraper and accurate measuring tools, finishing it properly from the bottom up. A great tool in the end.
AdBlock Detected
I've Disabled AdBlock
