Buy a qctp, and some tool holders, looks like a 9” lathe the axa size would work.
I use a Aloris wedge but there pricey,
You will probably need to make the t nut to fit .
Edit: Actually I think it was this one. From everything I read on them, go with the wedge type rather than the piston type post as the wedge is supposed to be stronger. You will have to mill the T nut to fit.
I have a 1937 SouthBend 9 inch lathe.
I added a King tool post: http://www.kingcanada.com/detail/kqct-0012/625
It seems to fit well.
I don't recall if I needed to modify the nut or not.
