4
4GSR
Forum Guest
Register Today
Lu,
I don't believe BM made a OEM base for their mill. They may of had a after market one to offer. That's why it called Benchmaster, made to fit on a work bench! Personnaly that stand is way too high for that mill. A typical work bench is 32-36" high, I would come up with one that high or close to it. Put it a height you are confortable with. The base needs a larger foot print than the one it's on now. Wood or steel construction, heavy large dimension wood to me would make a perfect bench. My $.02 worth.
Edit, Just relize from the pictures above, that bench is around 32-36" high. That means, the bench may need to be made to a lessor height, possibly.:thinking:
