- Jun 15, 2018
- 294
Chatter can be a real PITA for small lathes that are not very rigid. It may also become a problem when the work piece has a tendency to "sing".
The project, i am about to start, deals with the resonance type of chatter.
It is a simple micro controller powered device that alters the VFD speed periodically. The speed variation depth and frequency can be adjusted as well as the center frequency. The device is a simple add-on to any VFD that can be controlled by push buttons and whose speed can be controlled with a voltage (potentiometer). There should also be a suitable (12VCD) power output for this device. Most of the cheap chinese VFD's can be used with this one.
I have uploaded a video HERE.
Later on there will be the full documentation, program (source) code and the gerber files available.
