[4]
Variable Speed Motor Ideas
[3]
[10] Like what you see?
Chewy
New Member
Feb 28, 2016
23
Background: I bought a used Craftsman Wood lathe for wife. 12" swing and 4 speeds. The 1/2 hp motor developed starting problems, so for now it is under the bench and replaced with a Harbor Freight 1/2 hp motor. I am trying to work out the best possible way (and cheapest) to go variable speed. She wants to do off-center and off-balance turning in the near future. Haven't dissected it but pretty sure the HF motor is brush-less., so that eliminates a VFD since that say they only work with brush motors. Thinking about a 3/4-1hp 3 phase motor and a cheap inverter from EBAY. Suggestions about how to best do this and some recommendations for part names and numbers? Ideal would be a motor with 5/8 keyed shaft to reuse the old multi-step pulley. Pulleys are cheap so that is not a big problem. Anubody have any luck with using a variable speed pulley on a fixed speed motor? What about the DC motors and a VFD? Also if this works good. I would like to upgrade my Drill Press.
Thanks In advance! Charles
Ulma Doctor
Infinitely Curious
Feb 2, 2013
314
you may wish to look for a Nema 56 frame 3 phase motor in your HP range like this:
https://www.ebay.com/itm/Reliance-B7701693M-SH-AC-Motor-230-460V-1730-RPM-5-8-Shaft-Nema-56-Frame-Motor/182490829633?hash=item2a7d4d1341:g:Sc4AAOSw2gxYyas6:rk:93:pf:0
then you'll want a VFD like this.....
https://www.ebay.com/itm/1-5KW-VFD-7A-220V-SINGLE-PHASE-SPEED-VARIABLE-FREQUENCY-DRIVE-INVERTER-IP20-MX/263774216834?hash=item3d6a2b2282:g:sbYAAOSw5WVbfM-Z:rk:7:pf:0
these 2 items and some wire and some parameter setting will get you in the ball game.
i'm happy to assist you in making this a reality instead of thoughts and wants :grin:
JimDawson
Global Moderator
Staff member
H-M Platinum Supporter ($50)
Feb 8, 2014
7,667
Let me help you out a bit here.
DC motors will not run on a VFD. DC motor controllers are for brushed DC motors.
VFDs operate 3 phase motors only. Before I get flamed here I know there are special exceptions. :eek:
While the HF motor is in fact brushless, it is just a standard single phase squirrel cage motor. Can not be operated on a VFD
I would choose a 3 phase motor and VFD over a variable speed pulley system. You can run many VFDs on single phase.
Another option would be a treadmill motor and controller. Those are brushed DC motors.
EDIT: What Mike said above :)
Ulma Doctor
Infinitely Curious
Feb 2, 2013
314
Treadmill motors and MC60 motor controllers are a secondary means of accomplishing variable speed.
there will be a lot of modifying/making pulleys and/ mounting issues, unless you get a 56 frame DC motor
Hawkeye
Jun 17, 2011
1,873
What Mike means by modifying is that treadmill motors are generally of much higher RPM that induction single-phase motors. Hense the pulley mods. They do work well and are cheaply available, but you tend to pay in sweat equity.
mksj
Jun 12, 2014
2,119
You are limited by the motor frame size and shaft to something like a 3/4hp 3 phase motor. I would look into a motor/VFD combo as ther are some savings. Look at DealersElectric. The Teco L510 is decent for this application and simple to setup. A 1Hp motor is the next motor frame size. You should get better low speed control with the newer VFDs that run sensorless vector. You still may want to change to motor pulley size, so you can over speed the motor, typically 90Hz for this type of motor. Treadmill motor is an option, but matching up mounting, shaft size and getting the speed control working may be a bit more challenging.
https://dealerselectric.com/Package-P56X4109-and-L510-101-H1-U.asp
Chewy
New Member
Feb 28, 2016
23
Finally got time to respond. Have been researching the information. I bought the Reliance motor in the link from Ulma Doctor. Thanks. Bought a different VFD from model suggested only because more of the one I bought have been sold. Couldn't find any negative reviews. Going to start looking around for more 3 phase motors, for drill press. Bad thing is, a couple of years ago I gave them away because I had no need for them. Just things I collected in trading. If I don't find any soon, I will go with Teco package. Just trying to save money.
2 followup questions. The VFD says it can be controlled by external voltage source for 8 speeds. Has anybody rigged that up? It would be nice to give wife chart saying #1 is ##RPM, etc.
Does anybody have a solution, store bought or home-brew to install a tach on the lathe shaft. I can read it with a reflective tach setup that I used withe engines and pumps. It is a one time deal. I can always make a chart showing VFD percentage equals ##RPM, but it would be nicer with direct readout. Ditto for the drill press.
I'm starting to get spoiled with variable speed motors with readouts and DRO'S. Thanks to everyone for their assistance Charles
mksj
Jun 12, 2014
2,119
No real reason to use stepped speeds when you have a speed pot. The simplest approach is to use a 0-100 scale on the speed pot and then you can scale that off of the top speed for each range. But even easier is to buy a cheap tach for around $20 and mount it in a small box. Mount a single magnet to the lathe shaft and mount the pickup. Get a small wall wart or modular power supply to run the tach, and possibly a 12V LED light. Put the speed pot in the tach housing.
https://www.ebay.com/itm/Digital-Red-LED-Tachometer-RPM-Speed-Meter-Hall-Proximity-Switch-Sensor-NPN/171385171075
Chewy
New Member
Feb 28, 2016
23
Thank You! Thank You! On the way. I looked around on Amazon & Ebay but couldn't find a full kit setup like this to install.
Hawkeye
Jun 17, 2011
1,873
You can get project boxes at various places like Radio Shack or electronics suppliers. Just need to drill a few holes and cut the opening for the display.
Chewy
New Member
Feb 28, 2016
23
Follow Up. I got the Reliance motor (3/4 hp) and Ebay VFD. Everything worked on the test bench. Then the fun begins. I hooked it up to the lathe and it wouldn't turn an empty Head-stock spindle. I had to start fiddling withe the VFD parameters. Found out that the motor will only go up to 70 HZ. After that it slows down and stops going up to the 400 HZ. that the VFD produces. Had to increase the torque settings from 0. At one point the motor was running hot no matter what the settings or speeds. After two hours I got what I wanted and the setup works beautifully. 2 second start-up gives a slow gentle start. Control is locked to prevent reverse rotation. That keeps the chuck from spinning off the spindle. Motor stays at room temp no matter speed or load. My wife is in love with it. High speed turning down to low speed sanding almost instantly.
I am on the look out for another motor and will duplicate the setup on an old Delta school drill-press. It currently uses two belts and a movable pulley to change speeds. It's about 40 years old and still going strong.
I have potentiometers and switches on order from DigiKey to install on original control panel. I need to remote the VFD to keep it away from dust. Around $160-170 total cost which is not too bad considering what a decent 1/2 hp single speed motor costs. I haven't figured out how to install the tachometer pickup. There is no place to mount the magnet. I may have to make something to attach to the outer pulley.
Thank you to all who contributed. A successful conclusion!! Charles
warrjon
Active Member
Jun 26, 2018
104
Did you enter the motors RPM and Hz into the VFD, the VFD used these parameters to set the speed curve
bbaley
Active Member
Nov 14, 2018
62
Just a note on the Teco 510 - which I used on my 2x72 belt sander build.
There are some (software) settings you need to get right or you might experience some frustrating issues. I had a heck of a time with it until I came across some information provided by the mfg.
If you end up going with that unit I can try and find my notes on it.
Make sure you choose a motor with the correct max RPM for your application, you'll find 1725 rpm and 3450 rpm units out there.
I am guessing for the wood lathe you'll want the 3450 rpm...
mksj
Jun 12, 2014
2,119
You cannot run standard 3 phase motors to 400 Hz, at most I recommend 80 or 90Hz MAX. Below the motor base speed you loose Hp, so a reasonable speed range would be 30-80Hz. You would need an inverter/vector motor to go higher/lower and most of these max out at 5-6K and you loose a lot of torque. You need to adjust the VFD parameters to match the motor, this varies by the VFD brand/model. Typically you set the motor nameplate parameters such as base speed, poles, volts, amps/kW, etc., also some have an autotune for the motor. The VFD should be running sensorless vector mode if available. If you run a motor higher than it's base speed of 60Hz (US) then I often recommend going to a smaller motor pulley, in particular with a lathe.
[6]
[5] [7]
