Vevor VFD questions
randyjaco
Oct 5, 2010
1,044
I am in the process of setting up a 3 phase wood planer to single phase with a VFD. My electrical skills are minimal, but I have done this several times with other VFDs. Well, it seems that Vevor has its own way of doing things. I am trying to set up a simple VFD remote control. As you can see from the picture; there is an On/Off switch and a rheostat speed control. I can't figure out to connect the wires from the remote to the VFD. The symbols and locations are different on the Vevor :(
If speed responds backwards (speed goes up when you turn the dial down) then swap red and green.
Red is CW (clockwise) so that one should go to 5v out, green CCW to gnd, orange to center wiper 5v in
You could just take the faceplate off and use that. You'd need to buy a connector though.
Thanks Guys for the quick responses. I will do my best to keep the blue smoke inside. :grin:
