- Dec 19, 2013
- 73
On my lathe I have replaced my motor with a 3 phase 230 volt 1 hp Leeson motor. I am running this through a VFD from Automation Direct with 120 volt input, model is GS2-11P0. I have gone through the manual to set the VFD parameters where I think they should be and I can give further details. I was running my belt from the largest pulley on the motor to the smallest pulley on the spindle which was giving me about 2000 max RPM.
This is a recent CNC conversion and I have only been cutting plastic as I familiarized myself with things.
On to steel. On a .002 facing cut on 1.5" rod at 600 RPM running from the centre of the piece outward the lathe stalled at about the half way point. Increased the speed to 800, still stalled out. Backed everything off, increased speed to 2000 RPM, used my hand around the rod and I was able to stop rotation fairly easily. Then changed the belt to smallest at the motor to largest at the spindle, which gave a max of about 750 RPM and I could still hand stop the rotation. This thing just has no torque.
Changing the P2.00 setting from 00 general purpose to 01 high starting torque did not make any difference. When I changed this setting to 02 fans and pumps the motor did not turn at all.
First of all, do I have a problem or is this all I can expect from this motor/VFD combination? If I do have a problem where might I look to try and resolve it? All suggestions appreciated. Also I can provide further info on my settings if that will help. Thanks.
Dennis
Dennis
