Incoming single phase power gets hooked up to L1 and L2
The 3 motor power wires are connected U,V,W , and a ground wire goes from the motor frame to the VFD ground terminal
If you are using the VFD’s control panel for operation little more than programming is necessary.
If you want push button control and/or an ESTOP button , you’ll need a plan.
The DCM circuit can be used to operate the forward, reverse, and ESTOP along with a few other esoteric operations to boot.
An external potentiometer can be remotely located for speed control
I’d recommend reading the manual and follow the safety guidelines contained within., before proceeding.
The programming isn’t really hard, but a few parameters are critical, such as input voltage, braking time, ramp up time, and operation frequency envelope
