- May 3, 2020
- 99
Hey all, just a quick question. I have an Enco branded RF-30 with step pulleys for speed control. Nothing wrong with the setup, but I find the method for tensioning the middle pulley to be a bit of a chore, and generally feel the same about belt changes. This led to my thought of using a VFD to control speed to the motor, however I did realize that this could come with a few problems:
1. The motor will not be moving at it's rated speed if I am slowing down the spindle, which means the fan in the motor will not draw as much air and could lead to an overheat scenario
2. Pulleys also help provide torque multiplication that I could be missing out on by leaving the motor engaged on one position at all times, plus I believe I had read that VFDs lead to torque loss?
Would I be correct in both of these assumptions, and would they be severe enough concerns to make my idea a wash? I can deal with the belts fine, I'm just lazy .
