- Jun 12, 2014
- 4,816
You can get the metric Lesson motor, they work fine for this application and less expensive then the BC motor. Manufacturer Part Number: 192205.00 which is a 3 phase 1710 RPM motor. These come with a 24.0mm shaft, so not sure what your pulley size is, but may have to bore one. You can run a single belt, you do not need dual belts. The alternative is to adapt a US frame motor like the Marathon E467 which is a US 145 frame size and very compact since it is a TENV motor. Follow the links and look at the dimension drawings.
http://www.electricmotorwholesale.com/LEESON-192205.html
http://www.electricmotorwholesale.com/MARATHON-E467.html
