Cal,
No table removal was necessary, the screw freed up when I got the spanner on 12-353.
There were no stuck parts on the handwheel assembly, I just figured that something SHOULD go on the shaft section between the two threaded sections since there's a cut out for a Woodruff key, but nothing out past the dial assembly has a bore large enough to go past the first threaded section (save for 11-279 that threads onto the outermost thread)
