Hi All,
I have a VN16 mill with an overarm that won't fit back in its bore, and I'm trying to figure out how to approach the problem. This is probably out of my league, but I'm betting on taking my time. When I first got the mill, everything was very rusty:
With a liberal application of WD-40 and some time, I was able to get the overarm bar out with a mallet and a bolt of hickory as padding (trying not to mar the ends of the bar.) The overarm let go all at once and ended up on the floor, no doubt putting it further out of dimension. I spent some time with some scotchbrite to try to clean all the rust that was on it, hoping it would fit back where it was meant to:
The overarm is bent longitudinally maxing out at about 0.010 TIR in the middle (I put it in some v-blocks on the table under the ends of the bar, and put an indicator on the top of the bar, in the middle - not sure how accurate this would be, but that's where I got the number.) There are also a few hammer marks on the ends of the bar from some prior owner which may have upset the end of the bar. The bar will now only go about 3/8 inch back into its bore by hand, and I'm sure I don't want to drive it in.
I'm pondering a few different paths of action, sort of depending on what the problems are:
0) Should I just buy a piece of turned and ground 2.375 stock and call it a day?
1) Measuring and dealing with potential mushrooming / upset ends: Do I just take some calipers and compare the ends of the bar with the bore? If it is too big for the hole, do I take this somewhere to get ground, or is it something I could turn a few thousandths off of on the lathe? What kind of fit should I be looking for? I would like to do some horizontal milling on this machine someday, so getting it right is probably important.
2) Dealing with the longitudinal bending of the bar, should I get it pressed straight at a shop, or maybe flame-straightened? I don't think the bar being 0.010 out in the middle would cause the very end not to fit more than 3/4 inches (at that distance, it would be a deviation of less than 0.0003, right?) But again, I'm not sure how straight an overarm bar needs to be to work properly on a machine like this.
I'm sure I have overcomplicated this - this is a round bar that needs to fit in a bore, at a certain level of accuracy (which I don't know how to measure.) Any advice on how best to tackle this would be much appreciated. Thanks!
