- May 6, 2020
- 63
Which model is that?
Sent from my S61 using Tapatalk
Actually on mine there are two slotted plug screws and spring capped oiler. They feed directly into the shaft holders and spread through oil grooves.I believe there are 3 oil screws counter bored on the backside of the y casting that feed directly into the gear assembly. As well as the Oiler for the drive from the gearbox. I’m in the process of reassembling mine right now.
