  • How to Donate to Support the Forum and Upgrade Your Account
    To upgrade your account, click on your name/User ID, and your profile box comes up. On the right side (highlighted above) you will see "Account Upgrades" Click on this, and you will see your upgrade choices:
    * Premium Membership - recurring (12 months, recurring) $25.00 per year This is for one-year premium membership, automatically renews. Less ads, more access.
    *Premium Membership - non-recurring (12 months, non-recurring) $30.00 for 1 year This is for one-year premium membership, does NOT automatically renew. Less ads, more access.
    * Sustaining Membership - recurring (12 months, recurring) $50.00 per year This is for one-year sustaining membership, automatically renews each year. No ads.
    * Sustaining Membership - non-recurring (12 months, non-recurring) $50.00 for 1 year This is for one-year sustaining membership, does not automatically renew each year. No ads.
[4]
Wanted: 10" Tailstock for Logan 200
January Project of the Month [3]
[10] Like what you see?
SuperTroye
Steel
Registered Member
May 23, 2017
28
Likes
7
#1
Just got a Logan 200 and missing the tailstock. Ebay is no luck at the moment. Thanks!
SuperTroye
Steel
Registered Member
May 23, 2017
28
Likes
7
#3
Wow.. that is expensive! I called Logan, and a new complete tailstock for the 200 was $950. So, maybe not so expensive? Logan also said that any 10" tailstock would be compatible, so I bought one from eBay for a model 800. He said they were all fit for the lathe itself (hand scraped?) so I may have to shim to get it dialed in.
Anyways, thanks for your tip.
wa5cab
Downloads Moderator
Staff member
Dec 25, 2011
3,843
Likes
783
#4
Sup,
I assume that the front-back offset is adjustable (it is on most lathe tailstocks). Unless you turn a lot of parts that are long enough to need the use of a live center in the tailstock and are under about 1/2" diameter, I wouldn't sweat a vertical error unless the tailstock is more that about 0,003" to 0.005" too high (if it's too low, you can shim it, but no one makes negative shims). For a simple analysis relating diameter turning errors versus tailstock height errors, go to http://www.hobby-machinist.com/resources/tailstock-height-and-bed-wear-errors-txt.2479/ which is in the Atlas/Craftsman Lathes Repairs category in DOWNLOADS.
SuperTroye
Steel
Registered Member
May 23, 2017
28
Likes
7
#5
Thanks Bob, I will check it out. I have a lot learning to do as it pertains to machine set up. I also need to stock up on measuring gear. This is all still very much a learning process for me.
[6]
[5] [7]
