- Dec 5, 2017
- 464
I have a hydraulic sicklebar trimmer (Sabre Samurai) that clamps to the side of the bucket on my loader. Not terribly stiff. In fact, due to the leverage of the mount and the thin sides of my bucket, it flops around like a wounded duck. Plus, clamping it to the bucket puts the weight significantly forward of the loader arms, which doesn't help.
I bought a blank SSQA (Skid Steer Quick Attach) plate that mounts to my loader arms nicely, will pull things a foot or more closer to the tractor and allows for quick mount/dismount versus messing around with set screws and alignment, etc.
Plan A was to modify the original bracket and weld it to the SSQA which would stiffen things up nicely. However, looking at the bracket, I'd have to chop it up pretty significantly and if it doesn't work or I don't like it, I'm out of luck.
A spare fully adjustable mounting bracket with spring loaded break-away (all of which is a requirement) is $400 plus shipping.
I'm wondering if having the relevant pieces cut out on a water jet and weld up a new mount myself would save me any money.
I would need the two pieces with the arced adjustment slots cut in them. It's 10mm steel, but 1/2 inch would be fine.
Two questions:
1. Any clue at all what I should expect to pay? I realize this would vary by area/market but a ballpark figure would be helpful in making a decision. I do have two shops in a reasonable distance that have water jet cutting capability.
2. Do they need a CAD drawing to work from, or can I just leave the original for them to copy. If they need the CAD, it would obviously be cheaper for me to come up with a CAD drawing than to have them do it.
Two questions:
