- Sep 1, 2020
- 1,589
I messed that up right handed down cutting then I will have to measure it to see if it is a reamer.Braeden,
Likely is a reamer, but is still a right-handed tool, look at the cutting edge.
Although the spiral flutes are reverse.
-brino
Spiral flutes are for cutting holes that have interrupted cuts, oil slots, or the like. Pushing the chips forward makes sense for something that is open on both sides. It will not dig in like a drill, but instead takes pressure to make the cut. I'm thinking something specific like king pin, or wrist pin reamer.It is a few thou over 1 inch so it probably is a ream but it pushing work down does not make sense to me.
Thanks a lot that clears things up.Spiral flutes are for cutting holes that have interrupted cuts, oil slots, or the like. Pushing the chips forward makes sense for something that is open on both sides. It will not dig in like a drill, but instead takes pressure to make the cut. I'm thinking something specific like king pin, or wrist pin reamer.
