- May 27, 2016
- 3,469
I have a Philips headphone set that can only be called "a bit old", They be the "comfy" kind with the padded earphone large enough to fit over the entire ear, so against the head, aviator style.
For the third time now, I am cutting off the wires, and re-connecting from lead further back. Fortunately the twin-lead is well long enough to keep supplying fresh lead replacement. It's always the same. The last 9" or so of wire leading up to the earphone "goes very stiff". So inflexible that the wire breaks inside the plastic right near the earphone. The thing is, it is always the LEFT side that suffers this. The right side remains fully flexible, as does the remainder of the lead.
Very, very strange!
My best speculation is that maybe the left side sees more light from the window, but it's a North facing window, so no direct sunlight, and I thought UV gets blocked by glass anyway. Deterioration from light in this way hardly seems likely. I tried a couple of bluetooth phones with audio adapters, but none could be the "comfy" kind, and the presence of the adapter took over to exclude all other audio channel controls. The other adapter type that goes in the audio line socket and "transmits" to the phones just hit distortion way too easily.
So - back to the solder iron and tweezers. Once more, I will make it work for a last fling before I finally dump them.
Very, very strange!
